Every time I use mic conected to my Focusrite Scarlett 2i4 it has latency. So if I want to record some voice over in DJAY Pro, or talk between mixes got the latency issue… Is there a way to setup the latency time for the mic input from the app?
With the music works fine, no latency, just with the input mic.
Hi Mauro,
could you please contact our support, I am sure we can help you out.
Please tell them what OS you are running. Thank you:
I’m running OS X 10.9.5
