It seems like there’s a huge delay when pressing the fx bounce loop drums button. You have to press it before the desired beat.
Please correct this thank you. ![]()
Hi @SurvivorB, welcome to the Community! When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Hardware Firmware Version:
Please note that this feature requires Neural Mix analysis to separate the STEMS in real time. The speed of this will depend on your hardware. You can improve the latency by disabling Key Lock or using a Neural Mix operation when you first load your track (ex. adjust Neural Mix EQs or switch to Neural Mix multiple waveform display). I hope that helps!
Wow, thank you so much! I tried turning off the keylock and it seems better, but I guess I can’t play without it. That’s a shame.
My computer specs are: MacBook Pro 2017 / OS 13.7.8 / 16GB RAM.
And I used djay pro ver. 5.6.1 with ddj flx4.
It probably wasn’t strong enough, was it? ![]()
You’re weird @SurvivorB. Yeah that’s an older Intel based Mac so definitely not the most powerful by today’s standards.
Okay, I understand, brother. Thank you very much. ![]()
You’re very welcome @SurvivorB. Happy to help!
