Latency
Perhaps, for those who work with an external soundcard, it might be very useful to integrate an option to set the latency settings…
A very good idea. I use DJAY with a set of two cascaded Echo Audiofire 2 and Audiofire 4 external soundcards.
I had to play around a while to find out that the maximum ample rate should not be higher than 88,2 kHz. Otherwise click sound shows that buffer underrun problems can occur.
This could be much easier being handled by specifing a value for latency. Like Traktor Pro does for such issues.
Please implement this feature!
Algorriddm should accommodate all users. I am suffering rom underruns and would greatly appreciate . feature that allows me to increase the buffer size.
