Hi all,
I would like to know if I can open DJAY Pro in a specific screen.
For example, I opened DJAY in Pro mode, but dividing the track into vocal and instrumental.
Can I always open the app this way?
Hi all,
Hi @Alexseyn_Rodrigues, djay will automatically remember the previous mode you used (like Pro Mode). However, the other specific settings like Neural Mix layout are not.
Ok, obrigado Slak_Jaw
You’re welcome @Alexseyn_Rodrigues
