Less cramped library layout
as i run a 720 portable screen stacking libraries makes it hard for me to look for music . i like how vdj does things . its a simple window with the folders from my local drive and i can make a playlist easy in the same window with my list area . i just scroll to it make a folder and im good to go . change the folder inn almost any color and u can look for music easy plus it has many right click options .and i8 have the option to look for music on my drive and streaming at the same time without needed another window for it . i do think they need brighter colors for folders tho
Hi @CrossFade1200, thanks for the suggestion. I will share this with our dev team for consideration. Please note that you do not have to use the Split Library View in djay.
We also have a side-panel option for showing the Queue, Match and History
i know about that and i have beatport open and my music library open all the time for my gigs .:slight_smile:
Great @CrossFade1200
