Library, Column Live Filters
I have a suggestion that would improve track searching, especially with larger collections.
We have all the columns available in our library and playlists.
It would be nice, to be able to type in the column header for each column to filter the list.
This is for example how it works with Lexicon DJ (great software by the way!)
See here:
In above picture I have typed in:
“end” in the track title column
”scooter” in the artist column
”dance” in the genre column
The results are matching all criteria.
Of course, that would also work for comment, rating, key and anything else.
Together with comments, this is a very powerful tool to quickly find matching tracks.
I know, similar results can be achieved with the filters in DJay Pro, but they are fixed and thus a lot less flexible.
I would appreciate if you could upvote this to have the dev team looking into realization.
Thanks for the suggestion @Criwo. I’ll share this with the dev team for consideration.
Thank you @Slak_Jaw , appreciate your continous work and feedback.
Hope to Receiver more upvotes here!
You’re welcome @Criwo
Hello, I just had a wedding gig yesterday where music was widely mixed across many genres. I found myself scrolling a lot through different playlists in DJay.
This made me wish for this live filtering again. It’s so much of a help!
I would appreciate receiving more upvotes here, if one reads this.
Also, min & max year boxes, so you can efficiently narrow down to a specific date range (“only songs from the past 2 years”, or “classic house set 1985-1995”)
Thanks for the input @certuna
