Hi, when using Windows, I miss the option to import playlists/libraries from Rekordbox/Serato. There is an iTUNES option, but it’s a flawed method. Why? Because when I export to “iTunes” using the “Mixo” program, the order of the playlists is arranged alphabetically. After importing to “Algoriddim,” I have no way to arrange the playlists in my preferred order.
Additional question: Do you also experience slow scrolling in the music tab when you have around 10,000 tracks and sorting by BPM is enabled?
Your question:
Hi @mausikdj, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Please note, if you create playlists within the My Collection source in djay you will be able to reorder the tracks however you like. Reordering tracks within the Local Music / iTunes source is not supported.
