Library management: focusing (selecting for editing) fields in the library.
Hi. :slight_smile:
The creation of hotkeys and MIDI assignments for fields within the library is imperative.
For illustrative purposes, the following example is provided:
Specifically, if the hotkeys “Shift+C” and “Shift+L” have been configured, pressing “Shift+C” will direct the user to the “Comments” field, enabling the immediate input of a comment for the selected track.
Similarly, if the Shift+L hotkey is pressed, the “Color” field is accessed, enabling the selection of the desired color. This principle applies to all fields within the library.
Thanks for the suggestion @Zirrex. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Thank you. Voting is good, but it doesn’t always show the right direction. :smiling_face_with_sunglasses:
