I’ve not had that but now, sometimes when I load a track, the library opens on its side, not vertical. I have to reboot my ipad and then it works… For a while…
Note: This topic was created from a reply on the New glitch for djay for iPad 2 topic.
Hi Chewey,
We’re currently investigating this issue. If you notice any patterns as to when the library switches orientation, please let us know.
Which iOS version and djay 1 version do you have exactly? Also, is the problem reproducible?
I have the same problems! I work with the Numark Iday pro! And Djay1
