Hi I’m having loads of problems with the library not linking to tracks, I’ve tried the scan to relink tracks and it keeps freezing
Hi @Turf_Daz, can you please provide complete details for your setup?
Hardware Firmware Version:
Hi my Device is Apple M1 Max 64 GB Mac OS sequoia 2021 the version of Dj pro is the newest my hardware controller is a pioneer rev 7. After updating Dj pro version before this new one i now find my tracks are not found anymore in Dj pro not all of them but seems like its most of them when I go to scan to reconnect the files it gets about 10 minutes in and never finishes
Thanks for the additional info @Turf_Daz
Which sequoia exactly? Those OS updates have numbers to their names. Specify
15.7.7
15.7.7?? Been there
Either downgrade back to 15.7.1 (anything before 15.7.5 is fine), or upgrade all the way to Tahoe
You might wonna follow these 2 threads…
I don’t believe it’s anything to do with Mac OS
False belief, but hey
Let us know when you solve it (and how).
Hi @Turf_Daz, I spoke with our engineers about this. If you use My Collection can you please try reimporting all your music again via dragging the folder/files from Finder and dropping them into the My Collection Music playlist? This might help as it will recreate the bookmarks, which might work around the problem.
Will I lose my cue points and saved loops?
Hi @Turf_Daz, no you will not lose your cue points and saved loops. However, just to be safe, I recommend that you backup your djayMediaLibrary database file to the cloud or an external drive first:
Ok Thanks
Also will I lose my crates
You’re welcome. No, crates should be fine too. My Collection playlists and the Queue are also saved in the djayMediaLibrary database. If you’re worried about it, you could also do a full system backup via something like Time Machine first.
