Library tips & tricks!
Is there any way to sort songs by bpm and key at the same time like in serato?
I have not found a way, but you can sort by bpm, and use the filter to find only compatible keys.
Thanks for the tip @Stevie_Ray! This is exactly what I was going to suggest.
@paulmctin currently this is the only way to achieve something close to what you’re looking for.
I didn’t find this option on my mac, can you please show us how to acces it on mac?
@paulmctin select the icon to the right that looks a bit like the WiFi icon:
@Slak_Jaw Thank you :pray:
You’re welcome @paulmctin
