Hi, good day!
I just recently purchased DJ Pro. I followed the instructions but unfortunately the license key that I just input is invalid and im using mac os version 10.6.8
Hi, good day!
If you just purchased it, you should have purchased through the App Store. Just login and re-download.
Since you just purchased djay, and your mac is running on Mac OS 10.6.8, I believe, that you have a license key for djay4.
Please try to download djay4 here: http://www.algoriddim.com/files/djay_4.zip
If the code is also invalid for this version, please reach out to support(at)algoriddim.com
Best regards,
Lukas
