Can we have light mode in iOS please? Portable devices are more likely to be used outside where light mode is most useful.
Thanks for the suggestion! I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
@David_Lane, in the meantime, there is an excellent workaround on iOS that I use. Enabling Invert Colours works great (see below). I use Classic Invert. On iOS go to Settings->Accessibility->Display & Text Size-> and select either Classic Invert or Smart Invert
If you need to use this regularly, I suggest adding it the the Accessibility Shortcut within the Accessibility menu above. Then you can add the Accessibility Shortcuts to Control Center in iOS. With this enabled you can quickly access Classic Invert by swiping down from the top right of your screen.
Thank you, this has been added in 5.3, but there are some odd differences between iOS and Mac.
On iOS the larger waveform has a light background but on Mac it is not black but still a darker grey than before. At the top where the loaded track and overview waveform are that section is black on iOS but on Mac it is light. Overall I think the look on the Mac version works the best.
You’re welcome @David_Lane. Thanks for the additional feedback.
