Lighting Controllers - DMX and ILDA
Hi all - I’m a total newbie here so apologies if my question is a silly one or it’s been covered somewhere else… :thinking:
I was wondering if there is any way to link my sound output from DJ Pro 2 to either DMX or ILDA lighting controllers? e.g. ShowExpress, SoundSwitch, LaserOS etc?
I’m running MaxOSX Catalina 10.15.7 on one laptop and Sierra 10.12.6 on my backup laptop.
Thanks for any/all help and guidance from the Algoriddim community!
John
If you use any program that uses Abelton Link, then you can get Tempo informatino from DJAY to run sequences set up in your lighting software…I use a program on my iPad called StageLight. It talks Abelton to DJAY over the wireless network and then I use eDMX I Pro adaptor over Ethernet from my wireless router to connect to DMX. Works very well all around.
Thanks so much. I will check out your suggestions. I don’t use iPads though - do you know if these programs all run via USB connections?
