Add feature to like and add songs to my playlists when using Automix. I have the option in the Match sidebar, but would also like it when using the Automix sidebar.
Yes, currently it seems you have to manually search for the track to add the playing track in question in a list. Would be nice to able to drag whatever is playing on a deck in to a folder or hit a β+β to save for later
To add to this, Iβm using both OS X and iOS apps using local, Apple Music, and Beatport.
In both of them, when using automix, you need to change your view to something other than automix to have access to the track to hit + or Love. For instance, in OS X, if I switch to dual disc view and then open my sidebar with matching, I can like the track.
It would be great to be able to +, love, or drag the playing track in any view when automix is being used. Itβs a great way to discover new music and add to my folders.
Hi @jimyson,
To do this, open the sidebar in the Library and switch to the History Tab.
This will show the Current Session of your Automix.
From here, you can select the β¦ at the right and Add To Playlist.
