Listening to DJ Pro syncing tracks!
Hi, I have the problem that my dj pro started to sync two songs incorrectly. It will sync the second song to the first, but you can actually “hear” it working from bar to bar. I haven’t noticed this before and that is why I am here. Does anyone else have this problem?
Exactly. It is very minimal but still audible. And seriously from bar to bar. The grid keeps slightly moving back and forth. I thought a hard reset from my iPad would help but with no luck!
That’s strange! The first time I’ve noticed it in 2 years. At least THAT much to create a thread. At least I’m not the only one :slight_smile:
Indeed! I just bought a beatpad 2 and was also wondering if it was due to that but I guess not! I hope they intend to fix it!
You mean you can hear the key changing as it speeds up and down?
Then i have reassuring but bad news for you … Its quite normal in djpro (normal means everyone else has the same fault. We told algoriddm but as usual they take no notice)
My only advice is keep the keylock on … This seems to stop the key drifting.
It didnt happen with the old djay2 … But since they “improved” it with the updates before christmas these types of faults are common on djay2 and djpro
