Load button and browser knob malfunction with idj pro when using spotify libary and precueing switched on
Hi, I am using the idj pro controller from Numark with djay2 and spotify premium integration.
When I use the spotify library and press the load button with the precueing option ON (headphones are highlighted) both, the load button and the browser button of the idj pro controller do no longer work.
I can precue by tipping on a song, but when I want to load the song to the deck by using the load button or by pressing the browser knob, nothing happens.
When I switch back to itunes library everything works fine.
I am pretty sure that is a bug which came with on of the last updates. Does anyone has the same problem?
Hi Martin,
Sorry for the delayed answer. Thank you very much for your post, have you updated to our newest versions and does this problem persists after updating?
Thank you and keep it up,
i could not reproduce the explained issue. Could you guys please send us an exemplary video of the problem via support@algoriddim.com?
Thank you in advance.
Cheers,Lukas E.
i have the same problem
