Hi there. Does djay pro have ‘load markers?’ Really handy for you to load a track and straight away you are there where you need to be by setting a load marker cue
@Dysfunk_DJ yes, djay has load markers.
- These are set on your track by pressing the main Cue Button.
- They are identified by the White Triangle on the waveforms.
- You enable the load marker in Settings > General > SONG LOADING > Jump to Cue Point > Start CUE
@Dysfunk_DJ Alternatively, if you don’t want to jump to the temporary Start CUE, you can use one of the other options like Cue Point 1 or Earliest Cue Point (1-8).
Thank you. Can jump to 1st cue as well which is useful as can change colour and rename. Nice one.
