Load MIDI mapping on iPhone (iOS)
Is it possible to LOAD a .djayMidiMapping file on djay for iPhone (iOS) ?
I uploaded the file to my iCloud. How can I open it in dJay for iOS?
It is possible on an iPad. But on an iPhone?
On the iPhone, the way is exactly the same as on the iPad. If DJay Pro is installed on the iPhone, the system should automatically detect the link. If it doesn’t, you can also copy the file to the local folder that the app created after the first launch. When you then connect the corresponding controller, the mapping should be available and can be used.
