Load to protected deck - shutdown
On my ipad pro 11, It always crashes if you load a song to a protected deck. It gives you the warning, but if you hit load, then it crashes…everytime. It never used to do that.
The bug was reported and they are working on an update. For now, disable protected deck
See like this
djay 4.1.2 for iOS is now available on the App Store with a fix for loading with “Protect Active Deck” enabled. We’re very sorry for this mishap and will try to make sure this doesn’t happen again in the future.
Got it, tried it, it’s fixed. Thank you.
