- Device model MBPro 2018
- Version of operating system *macOS 15
- Version of djay 5.2.4
- Hardware/controllers used DDJ SX2:
Summary of the issue:
While playing a local track on either deck 1 or 2, if you edit the filename and hit enter, The track will cut out a few seconds later, and the wave file will show but the middle to the end is blank. deck is still playing but no sound.
this doesnt happen to streamed tracks cause the track names cant be edited
How to reproduce the issue:
Play any local track, then go and edit the filename, you will see that the track cuts out, no sound,
