“Locate Track” missing in custom shortcut settings
djay 5.3: New shortcut action “Locate Track” missing in custom shortcut settings
This is about the new “Locate Track” feature introduced in the latest version of djay. Pressing CTRL+L or COMMAND+L takes you directly to the playlist containing the currently loaded track—or both tracks if two decks are in use.
This functionality works great when using the new default built-in shortcut layout.
However, if you’re using a custom shortcut setup (like I am), you’ll need to manually add this new shortcut action. And here’s the issue: the new action “Locate Track” is not available for selection when editing your own shortcut list. It seems this action may have been left out of the editable custom shortcut options, even though it works in the new default set.
Hopefully, this can be added soon so users with their own custom shortcuts don’t miss out on this useful new feature.
Same problem here also.
Hi @DJ_Big_Blender, good catch! Shared with the team and they are working on a fix already.
macbook pro 2.3ghz 8 core
sonoma 14.3.1
djay pro 5.3
ddj400
Hi! When in the My Collection or Playlist I tried both modifier keys Cmd or Ctrl + L to locate the playing tracknothing happens. Am I missing something?
Also to see what playlists contains the right clicked track is there a key command for it?
Really cool update!
Hi @Donn, please use search before creating new topics. I’ve merged yours with this one. The team is aware of this issue and already working on a fix. Thanks for sharing!
Summary of the issue:
Command + L isn’t working and doesn’t show up in the shortcut settings. Initially thought it was user error, but another user confirmed the same issue and shared a video of my findings also.
I think you are talking about this one?
Hi @Owe_Marley, I’ve merged your new topic with this existing one. The team is aware of this issue and is working on a fix. Thanks again @DJ_Big_Blender for linking to your original topic - this is very helpful when I’m super busy! Really appreciated!
I believe this was addressed in the recent 5.3.1 release. Thanks!
Yes it is live and working now!
Many thanks
Excellent. Thanks for confirming. You’re welcome.
