Loop adjust mode?
  • Loop adjust mode – Dynamically adjust loop in and out points using waveforms or jogwheels on DJ controllers (via Loop In/Out Move actions)
Can we use this function in DVS mode? If so, how? Or, how do I set up custom in/out points. I can not find this function in app.
Any one knows about it?
Hi @DJ-Z, you can’t use a DVS platter or motorized platter to adjust the loop point like a jog wheel. What you can do is map an encoder to the loop point move mappings or map a button to loop in/out move and once you’re in the “move mode”, touch and drag the on-screen waveform.
