When deactivating loop it sometimes replays start of loop instead of deactivating which means it plays extra bars and messed up my mixes
Hi Aaron,
This is strange… Are you sure you’re exiting the loop before it ends? If you don’t do so the loop will replay.
If this is not the case, could you record a video of the issue and send it to us to support@algoriddim.com? Thanks in advance.
I am 100% sure I exited loop lol I’ve been a DJ longer than most have been listening to music and have been using djay pro since about 2015
The prog has bug issues that need fixing
This caching thing is a problem that needs to be fixed
What other prog has to cache cure points>?
