Loop direction option
  • Device model Macbook Air
  • Version of operating system (e.g. macOS Ventura 13.2.1):
  • Version of djay (e.g. 5.3.1):
  • Hardware/controllers used (e.g. Numark Mixtrack Pro FX:
Is there a way for you to change the loop halving from left to right so you can loop the end of a loop rather then go to the beginning? I am wondering if its in the midi mapping or a way to do it? Always when you half it it goes left, I would like it to go right. IF so please let me know.
Cheers
Hi @Gabberman1980, this is not currently possible.
Anyway it will be a possibility in the future?
Hi again @Gabberman1980. This is certainly possible. All user suggestions are considered and carefully evaluated, but not all can be implemented for various reasons. Please refer to the attached discussion for more details. Thanks!
