One minor thing I have noticed since the latest update and not sure if there is a setting for this,
So If I have a track loaded on a deck, and I press Cue say 8 which lets say for example is an outro beat. If I then press Loop the loop will stay on.
If whilst the loop is playing or even if the track is stopped. If I then press Cue 1, The loop switches itself off.
The way it worked before the update was the loop would stay on until I pressed the loop button off, which was handy because I would have a note on the Cue point saying Loop 8x for example on Cue 8 and before I start the track, I would press Cue 8, then press Loop and then start my track and the track would automatically go into Loop when that point of the track came up.
Is there a setting that I am missing?
I know this is also how saved loops works but it worked without having to prepare a saved a loop
Ok I have worked out what it is and with help from another thread, Slak Jaw pointed the setting.
Basically the Deactivate Loop When Jumping Outside Loop was turned on, I don’t remember turning this on so it may have been on by default.
Well I had a quick look through the threads and your explanation was the closest thing to my problem,
Was this something that was introduced by default on Version 5.2?
No problem thanks, I’m pretty sure it’s since 5.2 as It has worked like that before when I use my Rane One but I just picked up the Prime Go 2 weeks back and only noticed it the other day,
At first I thought it was a map setting on the Prime Go but when testing on the Rane One as well as the Buddy, I found they all were reacting the same…
I just installed version 5.2.10 today. I am using a Pioneer FLX6. Immediately afterwards, I started to play a song and wanted to loop a section on 8 beats. When I looped the section, it stuck there and now I cannot get out of the loop. It will not stop looping no matter what I do.
This has never happened before ever to me on any other version.
Hi @DJBK, welcome to the community! Sorry for the delayed response here and that you are experiencing this issue. To help me troubleshoot this with you further, please share specific details about your setup not just “iPad” or “Latest Version”.
Device Model (ex. 2020 iPad Air 4th Gen): Version of operating system (ex. iOS 17.3.1): Version of djay (ex. 5.1.3): Hardware/controllers used (ex. Reloop Ready): Hardware Firmware Version (ex. 2.7):
Please also confirm that you are have downloaded and installed the latest FLX6 firmware from Pioneer. Thanks!
