Loop + Gate noise on A Deck while B Deck is playing
Pc, Windows, no controller, lastest Djay version
While B deck playing then you prepare transition on A deck with loop+gate, the sound of this FX on the A deck is overdubbing while the B deck track playing, is this a post/pre fx send issue?
Best
Hi @JustineB, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Can you please also try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Not worth it, you just not launch the A deck during B deck playing, that’s it, but if you do it , you get the FX overdubbing…
