- Device model : macbook M4
- Version of operating system : macOS Tahoe 26.3.1
- Version of djay (5.4.4):
- Hardware/controllers used (Reloop Mixon 8 Pro):
- When triggering a looper pad, it’s not clear how it determines which beat it uses to start/stop. It does stay in sync, but the phrasing is off. Ideally it should always start stop on the downbeat.
play track on a deck
trigger any looper pad (from any pack) in between downbeats
C) EXPECTED RESULTS:
- looper pad should start/stop on the downbeat
D) ACTUAL RESULTS:
Note: It seems to correctly start/stop on downbeat more frequently if only one track is loaded
Hi @audiosymmetry, thanks for the details about your setup and for the video - this is very helpful!
- Does this only occur with the Second Column / Perc Loop Pads?
- Are those 2 songs Dynamic BPM or Straight BPM?
Thanks for the additional info @audiosymmetry
Thanks for the videos @thedrummingdj. Please share your update setup details:
Device Model:
Version of operating system:
Version of djay:
Hardware/controllers used:
Hardware Firmware Version:
Macbook Pro Max M1 64GB ram
Sequoia 15.7.3
5.6.3
no hardware.
Thanks for the details @thedrummingdj. Can you please re-upload your videos here directly. The ones above won’t play and the Dropbox links are invalid on my end. Thanks!
Thanks for the videos @thedrummingdj. This definitely clarifies things. I have moved your comments to this topic instead. Our engineering team is aware of this issue and is investigating further. Thanks!
maaaaan, I may have to fall on my own sword here -
I’m 99% sure this is my fault - I was working on my non-DJ computer - and I was also messing around with Claude Code - and it’s yet to be tested, but I bet what I was doing messed up the looper feature. I will uninstall and reinstall later today, but - I’m almost certain I broke it.
chiming in -
Have you tried using tempo blend in the crossfader FX? I’ve found using that - even if im not using in my transition does a better job of having those loops follow ‘master tempo’
I went to make a video of the above - but then - came up with a similar issue! I dont know if this is supposed to be like this or not - but - I caught ‘something’.
( I understand having a song start without a blend causes this, but, I feel like the loop/song should somehow be synced…)
Thanks for the video @thedrummingdj
