Can this feature be used in DJPRO 2 on the MAC?
Separately, can you somehow integrate both apps?
Hi Cameron,
So far the Looper is not available in djay Pro 2 for the Mac.
I am pushing the topic internally.
Hi Sacco,
The Looper is not stated in the Manual for Mac, only the FX “Looper” which is a Sugar Bytes Juggle audio effect.
Cheers
It says in the Manual for the MAC that the Looper is there… Where is it?
