Firstly I love the “idea” of the looper, it’s like having a mini Ableton, but without the possibility of creating our own packs is a little like owning a Ferrari that has no fuel - its just sitting in the driveway and nice to look at.
It’s a nice toy, but as a paid pro add-on hardly worth mentioning, or worth anything without being able to customize.
We NEED a way of creating our own packs, either via a tool, manual loading / saving
Secondly when if this feature becomes available, to make it useful we then need a means of switching between packs without any stoppage.
I could see this operating much like X-mix did on the old command stations.
For example we have two loop packs named “Pack A” and “Pack B”
Ch1 Slot 1 is playing a Drum loop from Pack A (this could be any number of channels active. )
If I select loop Pack B the music should not stop, that Ch1 Slot 1 from Pack A should continue to play.
When the loop is either stopped or a different sample on Ch1 is pressed (e.g slot 2) the sample from Pack A would then be unloaded and replaced with the New Ch1 Slot 1 sample from pack B.
This would enable true seamless playback across all loop packs essentially crossfading between loop slots.
