Looper separate output?
Hi, is there a way to send the Looper sound to a separate output? I often use multiple loops in my DJ set, like kick and snare loops that sync with the song’s BPM, but sometimes I wish I could manipulate the Looper sound even more. Right now, everything — both the song and the loops I add — is sent to the same bus/output. Any thoughts or tips?
I would like to agree with that. If you could feed the looper to its own external channel, e.g. on a mixer, that would definitely be an enrichment.
Hi @teddit, if you switch to External Mixer Mode in the djay Settings>Devices, you can route the Looper to a specific output.
Thanks for the help!
You’re welcome @teddit
