I’ve searched but couldn’t find any suggestions related to this - apologies if they exist…
The SoundPacks are great but kind of useless if you want to mix them in key with whatever track you might be playing. Seems to me it wouldn’t be too hard to introduce this feature and it wold make the SoundPacks feature massively more useful if you could.
Cheers.
Hi @Adam_Lindsay, are you referring to the Sampler Sound Packs or the Looper Sound Packs?
Oh sorry, I was referring the Looper Sound Packs
Even if you couldn’t change them by key in DJay just having the producers create packs in certain keys would be helpful - or a start at least.
Thanks for confirming @Adam_Lindsay. I have forwarded this to the dev team for consideration.
Also, a feature to keep key if bpm it’s changed will be nice!
