Looping problem. exits loop on own.
Yes ive had exactly same thing! Mixing while current song is in 8 bar loop & noticed loop had deactivated! I thought it was maybe me touching something accidentally taking loop off! But its happening all the time now! No neural mix just straight forward mixing!
Numark controller with iPad pro
The loop failure happens from a response and normally if I hit loop I am definitely multi tasking. So yes I agree
Last night at a geek, this happened many times.
Again last night during my 3 1/2 hour gig, it happened a few times where he exits a loop on its own but visually I can still see the loops in place
Thanks for the additional info @Nubium
again tonight with the latest app update
Same thing happened at my gig today also it beat jumped randomly a few times
It’s like a ghost is standing there pressing buttons…. I can’t trust it professionally at the moment. Hope this worked out soon
Thanks for the additional info @Five-0. This almost sounds like interference. Are you using a high quality USB cable with ferrite magnets on either end? Is your device and controller plugged into a high quality power bar/surge protector?
Yes all original apple products……and my back up cables are brand new . So I switch them out including power bricks and same results. Even when I switched to my M1 Mac book pro for my gig yesterday I had the same problems. It’s been ok but these last 2 updates have been a nightmare for my setup. Rev 1, Rev 5, and on a venues flx10 same thing. The only thing I haven’t tried was turning the Bluetooth off…. I’ll try that. Because after the update when y’all added the new Bluetooth Hercules controller that’s when my iuuses started
Okay thanks for the additional details @Five-0. Please report back if Bluetooth OFF helps. Thanks again!
Sadly turning off Bluetooth didn’t help. The only work around is to not rely on the loop
Thanks for confirming @Five-0
Device model MacBook Air M2 2023
Version of operating system MacOS 15.3.1
Version of djay 5.2.9
Hardware/controller DDJ WeGO 3
Same problem here. Exits loop on its own.
Hi @djkonski, welcome to the Community! Thanks for the additional info - I will share this with the engineering team.
Are we getting anywhere with this? It’s doing it so often now it’s making impossible to use professionally! Seems a lot of people are having the same issue now too!
Hi @JOHN_COPLEY, sorry to hear you’re experiencing this issue. Can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Same issues here. Very frustrating and confidence level is plummeting
MacBook Air
M3
Sonoma
DJay Pro 5.2.9
Numark NS4FX
It’s nice to know others are having the same issue so we can arrive at a solution. Unfortunately, it’s a frustration we all must deal with until it’s fixed or move on. I’m sure everyone’s threshold is different.
Hi @DJ-TOMYB, thanks for the details about your setup and sorry to hear that you are also experiencing this issue. Our team is still having a hard time consistently replicating this problem. Can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
