I activate an auto loop at the start of a track. it loops around as normal. I hit a button on Mixon 8 to half the loop length and sometimes even though the loop still looks active the track then continues to play as normal. I know you’re going to ask if I can get a video of it. ill try, again intermittent problem.
Hi @Nubium, thanks for the details about your setup and the issue. I was not able to reproduce this on my setup, but have passed it onto our engineering team for review. A video of the issue would definitely be helpful, so please share when you can. Thanks!
Hi. I do not have time to set things up and try to do this over and over again to catch video of it at the moment. FYI did a gig last night and it happened about 5 times in 3 hours. normaly happens when a track is playing though the sound system and the looped track has channel fader turned down. then when I start to bring the fader up the tracks exits the loop, however the loop “looks” like it is still active as it is highlighted. I hope this help?
Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro 11” 4th gen
Version of operating system (e.g. macOS 14.4.1): iOS 18.1.1
Version of djay (e.g. 5.1.2): 5.2.8
Hardware/controllers used (e.g. Reloop Mixon 8 Pro): rev 5
Summary of the issue:
I press auto loop. then if I hit sync or some times if I just move the crossfader it cancel the loop. It happens randomly so I can’t repo
Reproduce
Thanks for confirming @Five-0 and @strphone2128. We have still not been able to replicate this issue so it’s very challenging to troubleshoot and ultimately solve. It would be super helpful if one of you could capture a short video of this happening. Thanks!
At my gig last night the loop activated with no manipulation. I was in the middle of a transaction and when it activated it train wrecked the mix. (And I don’t need help doing that😂). Again it’s just random. But I was using stems and tidal at the time and touching the crossfader.
Last night, DJing again for no reason it just exits the loop sometimes when I’m not even touching anything. Just for information, it may loop round four times and then randomly exit the loop.
Hello everyone, our engineering team has done some extensive testing and have noticed they can sometimes trigger the playhead to leave a loop when putting a lot of work onto djay. For example:
Activate Neural Mix
Skip far forwards in small steps (e.g. 8 beats)
Activate a small loop
Adjusting the loop size
Does this sound like what you are experiencing or would you say your issue(s) are different? Thanks!
that is fantastic that the team have managed to do that. However, that is not my experience. the loop (normal of 16 beats) just randomly exits when im doing nothing.
yeah, same thing. I just start the track on a loop at the beginning, do nothing on that deck, just browse library, put some effects of a playing deck or just dance and do nothing, and then after a minute or so good chance the track will just move forward on it’s own.
Also, even the loop in the middle of a track can just release itself. Same behavior as described already, it stays activated, just exits on it’s own and track goes on.
