Why doesn’t Djay Pro hold a loop when you switch to a different cue point.
I concur with Joe, Djay 2 does this fine, both with and without a controller attached.
Would this feature be considered in an update?
Djay 2 does.
No I don’t understand!!!
If Djay 1 and Djay 2 do.
thank you for your post.
djay Pro holds a loop if the other cue point is in the range of the loop.
Hope you understand,
cheers,
