Loops staying active after jumping to a cue point!
Would it be possible to make a setting that allows an active loop in a song to stay active when jumping to a cue point? And another idea, in album view in the play lists, is it possible to show the “key” list like it is displayed in the album list view?
Hi Lukas,
No I would like to have a loop active somewhere in the track, and when I jump to a cue point, the loop jumped too! The loop is immediately active at the cue point after jumping to it!
Hi Lukas,
Yes, I’m using iOS pro with an iPad Air!
Hi Andi Copesetic,
for clarification, you want to jump to a cue point and after releasing the cue button jump back in the loop?
I would say this is hard to implement in terms of quantised.
You could work around the issue by using the Sampler and record the Hot Cue as a sample.
Hi Andi,
thank you for the follow-up.
Are you using djay Pro iOS?
Thank you in advance.
Hi Andi,
thank you for pointing this out. The feature is not implemented in djay Pro and i forwarded your thread as an push to implement it.
Stay tuned for updates.
