Help! I’m trying to run DJay on a Macbook Pro for an event tonight. I picked up an Asus Xonar U3 for pre-cueuing. If I pre-cue through the Xonar, I get a loud whine/buzz through the Xonar and good sound through the internal output of the Macbook. If I precue on the internal output, I get a loud whine/buzz on the internal output, and perfect sound on the Xonar.
So I know the Xonar is working. I know the internal output is working. But apparently the pre-cueing to a secondary device is messed up. Any tips or ideas? Or does this sound at all like a known problem?
first of all I wish to point out that I’m not an official support but “just” a user that is trying to help a collegue…
Install Midi Monitor and check if there is any strange midi activity
You can download it free from http://www.snoize.com/MIDIMonitor
Other option, if you have a passive DI box try to connect between the noisee output and the main mixer/amplifier.
