I have seen some youtube videos of a speaker system that prints the lyrics whilst a song is playing.
If this could be incorporated so that when a track is played, the lyrics are output to the video portion, you then have instant karaoke, just with the lyrics playing
So here’s the clever bit, could the software listen to the song, create the lyrics, but suppress the vocals via neural mix.
Karaoke DJ’s would not need to buy special version of tracks.
As I doubted the existence of a speaker with a built in printer, I Googled your phrase. Are you referring to the Cotodama speakers that cost £2000 each?
The lyrics are shown on a screen, not printed. The unit connects to a database to find the correct lyrics, but it’s limited (2 million tracks, compared to 100 million on typical streaming services).
The software (DJay) couldn’t “create the lyrics” by “listening” to the song, as the lyrics need to appear on screen ahead of time. It would require a huge database of lyrics.
VirtualDJ finds lyrics by searching online which can then be associated with the track, and yes the vocals could be muted via stem separation, but it’s a manual process.
I tried to find this using search but didn’t see any relevant items. I have seen that Rekordbox has a feature called Rekordbox Lyric, that allows the lyrics for the song playing to display on video, so people can singalong. I would like to see this feature on Djay.
Hi @afsaba, I’ve merged your new topic with this existing one. You can cast your vote at the top left of this page to show you interest in this suggestion. Thanks!
The new VDJ 2026 system is not the most accurate, but you can edit and correct mistakes. Also there’s the option of censoring explicit lyrics, both on screen and now in the audio too. You manually add the words you wish to censor.
If only the PC version of Djay Pro had a video output…
It does look pretty cool in Virtual DJ - I like how it places the lyrics above the waveform and shows where each word starts and ends! I think that would be super handy for finding a particular part to mix in quickly! The virtual DJ version looks a bit chunky, but I bet that Algoriddim could make it way prettier. Pretty, please?
