I’m considering purchasing a new MacBook Air M1 so that I can switch from iOS DJay Pro AI to the new Mac version. Currently I’m using an iPad Air 4 and a Vestax VCI-400 midi controller. This controller works perfectly with iOS DJay Pro AI. According to the Algoriddim website this controller is natively supported on both iOS and Mac OS. Is there anyone that can confirm this controller is working properly with DJay Pro AI on the new M1 Macs? Thank you.
Also I’d be interested to hear if anyone is experiencing any compatibility issues with other controllers and the new M1 Macs. Thanks.
Thank you for the quick response. I was hoping that was the case because I have never had to install drivers for it on my old Mac. Thanks again for your help.
