Mac Midi Mapping Location
Morning all,
So here I am with my new MBP and my first question.
I have copied my mapping file from the iPad and have it in iCloud.
I have also found the following folder in the MBP Djay folder:
/Applications/djay Pro AI.app/Contents/MIDI Mappings
If I put my custom map from iCloud into this folder is that it or is there somewhere else that custom mappings need to be?
Cheers
S :+1:t2:
Panic over… a bit of playing around, searching Spotlight, creating another MIDI map etc has led me to the correct place…
My folder / music / djay / MIDI Mappings
All under control!
:grin:
Glad you got it working, that’s the right location as documented here:
By the way you can also install mapping files simply by double-clicking them or dragging them onto the djay Pro AI app icon e.g. in your Dock. :sunglasses:
Cheers sanders, I’m fine with the iPad version but the MacBook is a whole new learning curve for me!
:+1:t2:
