I can set an automix start or end point cue without problems, but if i try to reset or owerwrite them I can’t do it.
Hi @Lorenzo_Foligna, to delete an Automix Start or Ens point:
- First select the Pencil edit icon then,
- Press the X to delete
If I click on Pencil, it come blue, but the x option is not present.
- What OS and version are you using?
- What version of djay Pro are you using?
- Please provide a screen shot of the issue so I can share this with the engineering team. Thanks!
I have upgraded to release 5.3 and now the problem is solved, i can see the
x option to delete the automix cue points. TKS.
