Mac Tool Menu Bar Item missing
  • Device model (MacBook Pro,):
  • Version of operating system (e.g. macOS 15.2):
  • Version of djay (e.g. 5.2.6):
Your question: I am struggling with the Djay app without Tool Bar Menu item, to close/minimize it to the Menu Tool Bar Menu whilst still listening to music and work on the Mac without anything visual about Djay on the Dock. Why is that not included? How many people with the app are actually Music DJs and so do not need that?
I guess more people who own the app are not Music DJs and just use the app because of its quality. I work but have pleasure at working and listening to music. Why won’t DJAY include this in the app?
Please help. Its an important tool.
I’ll appreciate your support, extend the DJAY’s strength and appeal to the user, please
Hi @Kwasi_Glover, thanks for the information, but I’m not sure I totally understand your question. Perhaps you could share some screenshots to help clarify? Thanks!
Hi again @Kwasi_Glover, it sounds like maybe you are in full screen mode. In which case the menu bar is hidden by default but can be shown by moving the cursor to the top screen edge. You can also exit full-screen mode by pressing Shift-Cmd-F. I hope that helps!
