I’ve been mapping control of DJay Pro AI to custom trackpad gestures on my M1 and came across the elgato stream deck – thinking how it might be an interesting combo, throw in deck pedal for control with your feet and … Hmmmm. Has anyone played with this setup or similar yet? Since elgato has some audio hardware - thought I would check. Might be a bit pricey to for me at this stage; just to play around with.
Right now I just left things at using trackpad mappings to control things like, transitioning next song, volume up/down couple others – works pretty cool - in this case just using it as a music player basically.
I’m upping this message…albeit I’m sure there are more pressing things on Algoriddim’s backlog. If no API control (which is understandable) then a custom stream deck or companion for stream deck integration would be amazing.
