MacBook Air M3 notch - less space?
is it possible, to use the full vertical resolution of the screen with DJAY, although the notch is at the top of the screen?
Actually DJAYs fullscreen window begins (in my case) below the notch and thereby I lose space.
Greetz Chris
Hi @Chq, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Can you please also share some screenshots to illustrate what you’re describing? Thanks!
Hi @Chq, I spoke with engineering and this is not possible. The default behavior of full-screen apps is to stay below the notch. Thanks.
Thank you for asking.
Greetz Chris
No problem. You’re welcome @Chq
