I use TRIAL presently but I cannot connect to Spotify… whereas in the machine I successfully use Spotify App…
I use the direct Login to Spotify login type (not Facebook)
pls advise
Same
An error has occurred processing your request. Please try again.
I also have this problem! It worked fine on the demo so I went and purchased the full version. Now I cannot use Spotify!
Does anyone have a solution? Otherwise I will have to request my money back - it simply does not work.
