macOS Mojave 10.14 & MIDI Controllers support
Hi !
I’ll like to know if there is any updates planned for macOS Mojave (10.14)
I’m no longer able to use my MIDI Controllers since the macOS update…
Thanks !
Hi Hugo. What Controllers where you using before you upgraded?
Hi guys,
Thank you for your feedback.
While we can not officially support running djay Pro on prerelease versions of macOS or iOS, MIDI and audio worked fine on macOS 10.14 in our preliminary testing.
Can you tell us which Mac model and MIDI controller you are using and what exactly is not working?
Cheers,Lukas E.
Hi everyone !
I’m using 3 devices but I only have issues with two of them :
  • KORG NanoPad2 : No issues, everything is working fine
  • AKAI APC Keys 25 & HERCULES DJ Control MP3 E2 : Not recognise in djay Pro 2 but works fine with other softwares
I’m using a Macbook Pro 15" with Touch Bar from 2016
Thanks !
