I’m sure you’re already working on it but it would be fun to be able to assign the effects to buttons on controller. Deck, Drums, Harmonics, Vox.
Hi tronque,
The Neural Mix is already MIDI mappable in via the MIDI learn feature, but it would be really interesting what exact MIDI options and actions you are missing in conjunction with Neural Mix.
Well since you can assign an effect to either deck or one of the neural stems it’s reasonable to see that function controlled with my midi controller and not via mouse or touch screen. Just an idea.
Also it’d be neat to be able to scroll only the ‘starred’ (favourite) fx. To save time.
