- Device model *ipad pro 11
- Version of operating system *17.6.1
- Version of djay *5.2.4
- Hardware/controllers used ipad only
The access to the area where you set start and end points for automix is mysteriously hidden.
When you go to the page the slice button does not have a drop down arrow. That is the problem, so if you did know something was behind it and you dont use Slice, why would you ever press it.
Once you press it , the the drop down apprears.
You then have to press it again, to access the 3 options. Pictures are in reverse order
