Make the gain controls bigger
YOUR SUGGESTION:
Make the gain button bigger and easier to control. A slider would be a better way to control the gain. Also, adding a keyboard shortcut to control the gain would be a big improvement and would you wouldn’t have to redesign the mixer.
Thanks for the suggestion! I’ll share this with the dev team for consideration.
Hi again @DoctorVapor, our dev team is wondering if a better/different auto gain would solve your UI issue or if the main issue is manually adjusting the gain due to its size/shape.
