Hi folks, did the developer ever add manual mapping to let users customize keys used for shortcut commands? Thanks.
@aleater yes, custom MIDI mapping is available for djay on iOS and MacOS. This applies to hardware controllers and keyboards.
If you mean short-cuts for the computer keyboard, please look at settings >> short-cut tab. Similar to Midi learn, but for what non-musicians refer to as keyboard …
You can map a MIDI controller in djay iOS and macOS.
There are also customizable computer keyboard shortcuts in macOS. iOS has computer keyboard shortcuts but AFAIK, they cannot be changed.
